Сообщение от MAGVAI
F5M22-1-VPKKLY7088 вот такую маркировку я нашел на каробке если не трудно подскажите встанет ли она на eclipse g1 94г.в передний привод не турбовый
привет вот тут глянь понятней будет
Какие передаточные числа у моей коробки ?
Длинный или коротки редуктор стоить у меня ?
Какие коробки бываю на DSM ?
Код:
| Gears | 1G 1,8 MT |1G NT FWD MT | 1G T FWD MT |1G T AWD MT |1G T AWD MT |
| | F5M22-1-VPKV | F5M22-2-VPZV | F5M33-2-SPZV |W5M33-2-NPZV |W5M33-2-NPXV|
| 1 | 3.363 | 3.363 | 3.083 | 3.083 | 2.846 |
| 2 | 1.947 | 1.947 | 1.833 | 1.684 | 1.684 |
| 3 | 1.285 | 1.285 | 1.217 | 1.115 | 1.115 |
| 4 | 0.939 | 0.939 | 0.888 | 0.833 | 0.833 |
| 5 | 0.756 | 0.756 | 0.741 | 0.666 | 0.666 |
| R | 3.083 | 3.083 | 3.166 | 3.166 | 3.166 |
| Primary | X | 1.096 | 1.208 | 1.275 | X |
| Secondary | X | 3.941 | 3.437 | 3.866 | X |
| Transfer | X | X | X | 1.090 | 1.090 |
| Final | 4.322 | 4.322 | 4.153 | 4.929 | 4.933 |
| Rear Diff | X | X | X | 3.545 | 3.545 |
Код:
| Gears |1G NT FWD AT | 1G T FWD AT | 1G AWD AT | | |
| | F4A22-2-MPD | F4A33-UP61 | W4A33-1-UP6 | | |
| | MPD1 | | | | |
| 1 | 2.846 | 2.551 | 2.846 | | |
| 2 | 1.581 | 1.488 | 1.581 | | |
| 3 | 1.000 | 1.000 | 1.000 | | |
| 4 | 0.685 | 0.685 | 0.685 | | |
| 5 | X | X | X | | |
| R | 2.176 | 2.176 | 2.176 | | |
| Primary | X | X | 1.125 | | |
| Secondary | X | X | 3.611 | | |
| Transfer | X | X | 1.090 | | |
| Final | 4.007 | 4.376 | 4.062 | | |
| Rear Diff | X | X | 3.307 | | |
Код:
| Gears | GVR4 | Galant VR4 | Galant GSX | Evo II GSR | |
| | W5M33-2-NQBK | W5M33-2-NQBM | W5M31-2-VQZH | W5M33-? | |
| | | (ZK,ZM) c 92 | VQBK | | |
| 1 | 2.846 | 2.846 | 2.846 | 2.750 | |
| 2 | 1.684 | 1.684 | 1.684 | 1.684 | |
| 3 | 1.115 | 1.115 | 1.115 | 1.160 | |
| 4 | 0.833 | 0.833 | 0.833 | 0.862 | |
| 5 | 0.666 | 0.651 | 0.690 | 0.617 | |
| R | 3.166 | 3.168 | 3.166 | 3.166 | |
| Primary | 1.275 | X | 1.680 | X | |
| Secondary | 3.866 | X | 3.100 | X | |
| Transfer | 1.090 | 1.090 | 1.090 | X | |
| Final | 4.929 | 4.933 | 5.208 | 5.433 | |
| Rear Diff | 3.545 | 3.545 | 2.846 | X | |
Код:
| Gears | 2G NT 2.0 |2G SPYDER 2.4 | 2G FWD | 2G AWD MT | |
| | | F5M31-2-VVXT | F5M33-2-SPZT |W5M33-2-MUZT | |
| 1 | 3.540 | 3.166 | 3.090 | 3.083 | |
| 2 | 2.130 | 1.833 | 1.833 | 1.684 | |
| 3 | 1.360 | 1.240 | 1.217 | 1.115 | |
| 4 | 1.030 | 0.896 | 0.888 | 0.833 | |
| 5 | 0.810 | 0.731 | 0.741 | 0.666 | |
| R | 3.420 | 3.166 | 3.166 | 3.166 | |
| Primary | X | X | 1.206 | 1.275 | |
| Secondary | X | X | 3.437 | 3.800 | |
| Transfer | X | X | X | 1.074 | |
| Final | 3.940 | 3.625 | 4.153 | 4.929 | |
| Rear Diff | X | X | X | 3.545 | |
Код:
| Gears | 2G AWD AT | 420A AT | 2G FWD AT | | |
| | | F4ACl-3-QZAF | F4A33-1-UPQ | | |
| 1 | 2.551 | 2.842 | | | |
| 2 | 1.488 | 1.573 | | | |
| 3 | 1.000 | 1.000 | | | |
| 4 | 0.685 | 0.689 | | | |
| 5 | X | X | | | |
| R | 2.176 | 2.214 | | | |
| Primary | 1.228 | | | | |
| Secondary | 20149 | | | | |
| Transfer | 1.074 | | | | |
| Final | 4.359 | 3.909 | | | |
| Rear Diff | 3.307 | | | | |
Код:
| Gears | 3SI AWD | 3SI AWD | | | |
| | 1991-1993 | 1994-1999 | | | |
| 1 | 3.071 | 3.266 | | | |
| 2 | 1.739 | 1.904 | | | |
| 3 | 1.103 | 1.241 | | | |
| 4 | 0.823 | 0.918 | | | |
| 5 | 0.659 | 0.733 | | | |
| 6 | X | 0.589 | | | |
| R | X | X | | | |
| Primary | 1.375 | 1.222 | | | |
| Secondary | X | X | | | |
| Transfer | 0.815 | 0.958 | | | |
| Final | 3.972 | 3.869 | | | |
| Rear Diff | 3.545 | 3.307 | | | |
Комент на форуме:
Давно вас читаю и всё больше горжусь нашей страной: вот уже и в дурдомах интернет доступен.
Последний раз редактировалось kasem; 21.02.2007 в 06:11..
kasem вне форума Пожаловаться на это сообщение Ответить с цитированием Перейти в начало страницы Перейти в конец страницы
Старый 01.03.2007, 18:35 #2
kasemМеню пользователя
Аватар для kasem
Авто: 1G 2.0 Turbo MT FWD (D22A, 1991)
Маркировка AWD коробок W5M33-2
инфа от Karabas
Последние 4 буквы отличают коробки передач..
1я буква - Final drive ratio
N = 3.545 ratio
W = 3.909 ratio
2я буква - gear ratios??
O = dunno ratio?
P = dunno ratio?
Q = close ratio?
R = wide ratio?
3я буква - front diff
B = open front diff
F = ?
G = ?
W = viscous front LSD
X = ?
Y = open
Z = ?
4я буква - На какой автомобиль ставилась.
Mounting locations?
D = CB Lancer
E = CC Lancer
K = HH/HJ Galant
M = Galant
S = 89-90 Eclipse AWD 5spd
T = DSM G2
V = 91-94 Eclipse AWD 5spd mfg 6/90-2/94
Front LSD uses a different crownwheel, and a longer drivers side inner
CV joint
Ну и пару примеров:
..GearBox Code.....Vehicle.................................. ................................... Front LSD.......... Ratio
W5M33-2-MUZT.....Eclipse AWD 5spd turbo mfg 7/96-end
W5M33-2-NGRE.....Lancer gsr RS (1992, 1800cc)
w5m33-2-NNXL.....Expo 2.4 AWD non-turbo 5spd mfg 6/92-2/94
w5m33-2-NNXZ.....Expo 2.4 AWD non-turbo 5spd mfg 5/91-5/92
W5M33-2-NNZT.....95? Eclipse AWD 5spd mfg 3/94 [not sure about this one]
W5M33-2-NOBE.....Lancer GSR 3.545 no LSD
W5M33-2-NPXV.....91-94 Eclipse AWD 5spd mfg 6/90-2/94
W5M33-2-NPZS.....89-90 Eclipse AWD 5spd mfg 1/89-6/90 [change shift linkage]
(с) RussianE39 NPXV покрепче, чем NPZS. Если память не изменяет, первая 332ая коробка с двухконусным синхронизатором 2ой передачи.
У NPZS конструктивный дефект - более выраженная вероятность потрескавшегося колокола.
W5M33-2-NPZT.....95-96 Eclipse AWD 5spd mfg 3/94-6/96
W5M33-2-NQBE.....Libero/Lancer Gsr 1.8rs, non lsd version of NRWE........No................3.545
W5M33-2-NQBK.....1991-92 to 4/92 Galant VR4/Eterna ZR-4
W5M33-2-NQBM.....Eterna ZR-4 1990, Galant VR4 to 5/92
W5M33-2-NQXV.....Sheriot 4wd, 1990, 4G63t
W5M33-2-NQZS.....Eclipse GSR-4 (Japan) вып. 09/89-12/90, код MD995574
W5M33-2-NRBE......92-95 Lancer GSR, lightweight synco's 2nd & 3rd..........No................3.545
W5M33-2-NRWE.....92-95 Lancer GSR, stronger box, dbl syncro 2nd..........Yes...............3.545
W5M33-2-NRXD.....1990 Cyborg hatch (4WD) .............................................No... .............3.545
W5M33-2-UPFE......Evo3 RS with front LSD............................................... ...Yes................3.909
W5M33-2-UPGE......Evo3 GSR non LSD .................................................. ......No................3.909
W5M33-2-UPWE.....Evo3 GSR with front LSD ..............................................Yes. ..............3.909
W5M33-2-UPYE......Evo 2 и Evo 3 RS non LSD ..............................................No.. ..............3.909
W5M33-2-WNZT.....95-96 Eclipse AWD 5spd - ?
W5M33-2-WPBV.....Eclipse AWD АТМОСФЕРНЫЙ "европеец".
W5M33-2-WPFE.....Evo2 RS with front LSD .................................................Y es...............3.909
W5M33-2-WPGE....Evo2 GSR non LSD .................................................. .......No.................3.909
W5M33-2-WPVF.....Cordia GSR - 4WD (Galant VR4 E84A ? твин турбо).......No.................3.909
W5M33-2-WPWE....Evo2 GSR with front LSD ...............................................Yes ...............3.909
W5M33-2-WPYE.....Evo2 RS non LSD .................................................. .........No.................3.909
W5M33-2-WQFE.....Evo1 RS with front LSD............................................... ...Yes...............3.909
W5M33-2-WQFK....Galant VR4 evo ? ?
W5M33-2-WQGE....Evo1 GSR non LSD .................................................. .......No.................3.909
W5M33-2-WQNK....Galant VR4 Evo, close ratio box ? ..................................No.............. ...3.909
W5M33-2-WQWE...92-93 Evo1 GSR (and RS?) (viscous front LSD) (3.909)
W5M33-2-WQYE.....Evo1 RS non LSD .................................................. .........No.................3.909
W5M33 - C5TPH = 1988 Galant VR4, Open Front Diff, 3.545 Ratio
4G63 (DOHC 16v) + KM-206 Transmissions 89-92 Galant, Eagle 2000 GTX, 92 Colt Turbo
c50ph -> is the switchable tranny (2wd/4wd)
c51ph -> if for the 88-89 JDM VR4 (early GVR4s) and select foreign market (a specimen was reported in Australia for example) GVR4s
From my friends with a switchable 2WD->4WD JDM Galant trans that I would LOVE to get a hold of:
C5OPH-EK1420 or C5JPF-FL8420
See
http://www.vfaq.com/mods/Tranny-switchable.html for more details.
Полезную информацию еще можно подчерпнуть ТУТ щелкнуть мышкой
Спасибо Doctorу и
отдельное БОЛЬШОЕ спасибо Mustangу.
от mustang
W5M33-2-WPVF 3.909 -4WD Cordia GSR ( выше Galant VR4 E84A ? твин турбо), может на той и той?
На эту коробку добавить диф -W5M33-2-NRWE 3.545 92-95 Lancer GSR, Viscous Front LSD, 3.545 ratio.
На эту подкорректировать, что нет ЛСД -W5M332WQNK -for a VR4 Evo -non LSD front diff, close ratio box, 3.909 ratio
На эту можно дописать, что это Митсубиши Этерна
А то может не сразу можно догодаться что такое ZR-4
W5M33 2NQBK and under that it reads KD6377 -1990 Mitsubishi Eterna ZR-4
как мужик переделал талона самита 1,5 в 2,0турбо вот есть коробочка новая для моего взгляда, плиз добавьте в список
http://www.pixcl.com/summitgtx/lancerproject_1.htm
(с)
На Иглах Саммитах 2,4 авдшных тоже были коробки W5M33..вот тока продолжение не могу найти((
от costarika
