Старый 24.07.2016, 21:17   #1
Junkman
Аватар для Junkman
Авто: Galant VR-4 E39A АКПП
Хорошая статья про AFR.
Quote Originally Posted by Cliff on VEMS Forum
Fuelling Theory
Let's start with the theory then. We are concerned with spark ignition gasoline engines here. I'm only going to cover gasoline, since Diesel is for trucks and diggers, and alcohol is for drinking and drag racing.
Chemistry
Now you might think that petrol is petrol right? Not exactly. You will probably have heard the term "hydrocarbons" before, perhaps as part of the MOT emissions check. Hydrocarbons are raw fuel. They are a chemical compound of hydrogen and carbon. Without getting into too much of the chemistry, there are different fuels, the simplest of which in structure (the alkanes) consist of chains of carbon molecules, each linked with the next carbon molecule and with two hydrogen molecules. The end carbons then have an extra hydrogen. This leads to a family of fuels with the chemical formulae CH4, C2H6, C3H8 etc. These three examples are more commonly known as methane, ethane and propane.
Now because of the weird and wonderful way in which chemistry works, you can also get different arrangements of atoms, where the structures vary according to which H is bonded to what C, and how strong the bond is. Take for example C7H16. For the same number of C's and H's, it can be arranged in four different ways. Why is this important? Because the structure defines their properties as a fuel, and how they are broken down when they burn.
We're all familiar with the RON value of petrol right? (If not don't worry, I'll come to it in a bit). A higher RON means the fuel is more resistant to knocking (self igniting). Well for our example C7H16, n-heptane has RON of 0, i-heptane (2,4-dimethylpentane) has a RON of 83, i-heptane (2,2-dimethylpentane) has a RON of 93 and good old i-heptane (2,2,3-trimethylbutane) has a RON of 112.
Overall a typical gasoline is predominantly a mixture of paraffins (alkanes), naphthenes (cycloalkanes), aromatics and olefins (alkenes). The exact ratios depend on the oil refinery that makes the gasoline, but with ever stricter requirements from manufacturers and government, gasolines from different companies are generally very similar in composition.
As you can imagine, there is a whole lot more to fuels than this, and that is why fuel companies spend a lot of money on research, playing with new blends of fuels and various additives (anyone remember lead) to improve certain desirable qualities. Here are a couple of interesting links to start you off.
http://www.atsdr.cdc.gov/toxprofiles/tp72-c3.pdf
Chevron Products: Ask Mr. Gasoline
If you need to know more about fuels, then find yourself a good book on the subject like I did. The information in this section "Chemistry" is taken from Chapter 3 of "Introduction to Internal Combustion Engines" by Richard Stone. Don't act so surprised that I didn't have all this info in my head. Hey I'm an engineer, not a chemist!
Combustion
So that's the fuel itself, but how do we get any useful work out of it. Firstly we need to unite the fuel with oxygen (which comes in air as O2). We mix the fuel and air together so that we get a good chance of O2's being near to CxH's, and if we have done a good job of mixing it (so that the fuel is spread out evenly through the air) the mixtures is called "homogeneous", and this is the condition in which we will get the best combustion. Once we have ignited the mixture with a spark, a chemical reaction occurs where the C's, H's and O's all swap around and end up as CO, CO2 and H2O, plus some extra heat. The heat makes these gases (combustion products) expand, and that drives the piston down the cylinder and voila, we have power!
Complete combustion occurs when just the right number of O2's are available to react exactly with the number of CxH's we have so that all the C's H's and O's get converted. We express this "stoichiometric" mixture as the ratio of mass of air (since we actually ingest air, not pure oxygen) to mass of fuel. This is the air fuel ratio (AFR), and this turns out to 14.7:1 for air:gasoline.
Another way to express the AFR is as the excess air factor. Or to put it another way, the actual AFR/stoichimetric AFR. This value is called lambda. Lambda=1 equals AFR=14.7:1 for gasoline.
Lambda Efficiency
In just the same way that the engine can still run with different spark advance, it can also run at different air fuel ratios. There are some pretty complex interactions occurring here.
As the fuelling increases, the incoming aircharge is cooled (as it loses its heat to the fuel), increasing the charge density, which as we know is a good thing.
The highest flame speed has been found by research to occur at a lambda of about 0.82. High flame speed is good because it increases thermal efficiency by reducing the time available for heat to be transferred to the cylinder walls, meaning the gasses expand more, and hence make more power.
Theoretically, the highest combustion temperature occurs at the stoichiometric AFR, but in reality the highest temperature is reached at the lambda of around 0.88. This is due to thermal decomposition and that's about all I know about it. High combustion temperature is good because the more heat we get (assuming the engine can cope), the more expansion we get, and hence more power.
Lastly, the highest exhaust gas temperature is found at around lambda = 1.
If we combine those effects, and if we consider the engine torque produced at stoichiometric to be 100%, then we can plot a lambda efficiency curve, just as we did with ignition timing.
The key points are that the best lambda efficiency is at around 0.86, and this point is called the Lambda for Best Torque (or Leanest Best Torque, LBT). This is an important point to note. ADDING MORE FUEL DOES NOT GIVE YOU MORE POWER. Lambda is simply a measure of the ratio of fuel and air in the cylinder. The only way to get more power from the engine (assuming you have optimised the ignition timing) is to burn more charge - the mixture of FUEL AND AIR.
The running limits of the engine are generally around lambda 1.2 on the lean side, and lambda 0.65 on the rich side. Outside of this region combustion becomes unstable, and eventually the engine starts to misfire as there is either too little or too much fuel for stable combustion.
Lastly, the catalyst window of operation is around 0.98 to 1.02, and the fuelling must be cycled between these two values in order for the catalyst to operate correctly. This will be important if you are fitting your engine management system to a vehicle that still has to comply with catalyst emissions limits for MOT or SVA. If you want to know why and how three-way catalysts work, have a look here;
Catalytic converter - Wikipedia, the free encyclopedia
Fuel Octane Number
We briefly touched on the RON value of fuel earlier, and I said I would explain a bit more, so here goes.
The octane rating of fuel is a measure of its knock resistance under fixed test conditions. For a description of knock, see the ignition section. The Octane Number scale is based around two known fuels. N-heptane, which was given an octane number of 0, and iso-octane, given an octane number of 100, for no other reason that these fuels were easily available in a pure form when this rating system was being developed. All other fuels are then tested using a single cylinder research engine of variable compression ratio, and compared against these two reference fuels. From these tests, the fuels octane number is derived. Note that these 2 fuels do not represent the ends of the scale – ironically n-octane has a RON of -20, and methane has RON of 120. Additives can increase this even further. US wartime aviation gasoline was commonly as high as 150 RON. Unfortunately many of these additives are either incompatible with catalysts, bad for the environment, expensive- or all three! This generally makes very high octane "race" fuel a rare and expensive breed.
There are several different ways of quoting the octane number. In Europe, we commonly use the Research Octane Number (RON). However, another (and some may say more representative method) is the Motor Octane Number (MON), which provides a value under different test conditions to RON, but still using the same reference fuels. In the US, the quoted value is sometimes the roaD Octane Number (DON), also called the Anti Knock Index (AKI), which is the average of the MON and RON values of the fuels. This used to be an important distinction, since fuels of the same RON may have different MON values depending on the blend of the main constituents. Nowadays however, with increasingly stringent legislation and requirements on fuel blends for cars, the RON can generally be considered as being 10 points greater than the MON of available pump fuel, and hence the DON and AKI is halfway in between.
Here is another important point to note. RUNNING ON A HIGHER OCTANE FUEL DOES NOT GIVE YOU MORE POWER. The extra power comes from advancing the ignition timing to take advantage of the better anti knock properties. Modern OEM systems do this for you (active knock control) and most high performance engines with cylinder individual knock control are now calibrated on 100RON fuel, and the knock control system adjusts the ignition timing to allow them to run safely on 98, 95 or even lower RON fuels. However, aftermarket systems (that I know of) still do not have this fine a level of control, and any "knock control" functionality is a safeguard at best. Therefore, as I said in the Ignition section, map the car on the fuel you intend to run. If you think you might want to run different types of fuel, then you will need to map the car on each type. As we will see, this is not just ignition mapping, but affects the target lambda maps too.
Volatility
As well as all the other requirements we put on fuel, it also has to cope with changing temperatures and barometric pressures. Remember I mentioned mixing the fuel with air? Well one part of this mixing is through evaporation, or vaporization. As we already know, gasoline is actually composed of a complex mix of fuels. Some of these will turn into vapours (gasses) at quite low temperatures. Others will remain liquid until they get quite warm. During starting the engine, the amount of airflow and hence fuel required is relatively small. This means that the physical mixing of fuel and air is less effective, since there is less charge motion to help break up the droplets of fuel and mix them with the incoming air. This is where we rely on the "light ends" of the fuel to vaporize. It is this part of the fuel that starts the car. Much of the rest of the fuel is wasted initially until the combustion chamber and inlet ports warm up, and we are able to increase the engine airflow. This is why we increase fuelling for cold temperatures, but we'll cover this in more detail in the starting section.
So when the weather is cold, we need a high volatility fuel that vaporizes easily to allow easy starting. The flip side of this is that when everything gets too hot, liquid fuel can turn to vapour in the fuel rail and cause a "vapour lock", whereby when you open the injector you get nowhere near the amount of fuel you expect (the density has decreased dramatically). This commonly occurs after the car has been driving until warm and then stopped for 20 - 40 minutes, allowing the heat of the engine to "soak" into the engine components and the fuel in the rail itself. To avoid this we need a low volatility fuel. We can also increase the starting fuel, just as we do when cold, to compensate for the reduced density effects.
To try and meet these 2 conflicting requirements fuel companies actually change the volatility of the fuel available during the year. In some countries this may be in 2 or 3 steps through the year. In the UK we normally just have winter (high volatility) and summer (low volatility) fuels.
As an aside, you've heard people say they left the car for a while and when they came back the petrol was "stale". All that means is that the light ends have vaporized from the fuel in the tank, and left only the low volatility fuel. In extreme cases this will make starting the car difficult, but in reality there is nothing much wrong with the fuel. Mixing it 50:50 with some fresh (preferably winter) fuel will normally solve the problem (if there is one) and mean you don't have to throw it away.
Fuel Density
Fuel does in fact change in density with temperature, significantly enough to warrant attention. The chart shows the curve that was generated for the fuel dispensing industry in order to correct the delivery of fuel pumps.
In the engine, our air fuel ratio requirement is based on mass. But injectors are flow devices. So in order to calculate the correct mass of fuel from the injector open time, we also need to know the fuel density. Or to put it another way, in order to inject the correct amount of fuel under all conditions, we need to correct the injector pulse width based on the fuel temperature, using the percentage corrections above.
Over-fuelling -- why do it?
You'll have seen tuned cars (usually turbocharged) at the track which when accelerating hard leave a trail of black smoke behind them. This is one side effect of serious over-fuelling. We can see from the theory above that we would ideally run around lambda 0.86 for peak lambda efficiency, but there are 2 good reasons for running richer than this.
Due to the high gas flow rate at high engine speeds, and under heavy loads, the exhaust components (e.g. exhaust manifold, turbo, O2 sensors) are subjected to very high temperatures. In order to keep these components at or below their temperature limits (800 to 950°C), the fuelling is increased (richened) to lower the exhaust temperatures. This happens because of the lower combustion temperature of mixtures richer than lambda 0.88, and the initial charge cooling effect of the additional fuel, as we have seen.
The very same cooling effects also reduce the chance of knock during combustion, since the in cylinder charge and combustion temperatures are lower. This is why some tuners take the approach of running extremely (some may say excessively) rich mixtures, in order to allow more spark advance, and to protect the engine components from excessive temperatures.
Personally that's not how I calibrate engines (who wants their car to look like a diesel when they tip in?), as I feel it's wasteful of fuel for a minimal benefit. It also increases the chances of other problems - more delivered fuel requires larger injectors, more pump capacity etc, and the excess fuel may increase bore washing effects (where the fuel literally washes the lubricating oil film from the cylinder walls), reducing piston ring and cylinder life. However, I can understand the rationale and the potential for a little more power, so if that's the only thing that matters to you, then feel free to try it.
Summary:
Intake charge is cooled with more fuel (see image) Colder charges resist detonation.
Highest flame speed is at 12.0:1 A/F ratio (see image). Higher flame speeds resist detonation and make more power.
Highest combustion temps are found at 12.9:1 A/F ratio (see image). Higher combustion temps translate to more power. Lower combustion temps resist detonation.
Leanest Best Torque is found at 12.6:1 A/F ratio (see image). More fuel than this loses power.
Anything richer than 12.6:1 is considered "over-fueling". This is done for various reasons.
If you've read the entire quote and made it this far, you're probably exhausted, but I commend you. If you haven't read it and just read the bullet points, you should be okay.
Basically, we'd like to run at 12.6:1 A/F ratio to make the most power. This is a generalization based on real world experiments, and every engine is different, but for our sake we can run with this idea.
We can't run at 12.6:1 A/F ratio while boosting our engines, we know this. In practice, it doesn't work out very well. Detonation will kill the fun most likely, and very quickly. This means we need to over-fuel to an extent to keep our engine alive. We don't have perfect exhaust manifolds, turbos, intakes, cams, etc. so we loose a lot of efficiency. Because of this, detonation will rear it's ugly head. We'll need to keep it at bay. How much extra fuel do we use?
If your set-up is decently built, with attention to detail and all that jazz, you should be just fine at 12.0:1 A/F ratio. This is a lot of extra fuel. How much extra? Well, to put it into perspective it's the difference between a mild acceleration ratio (13.4:1) and WOT on a tuned N/A engine (12.8:1). It's a lot of extra fuel.
Keep in mind, since the A/F ratio stays the same throughout most of the rev range (if you've tuned it so) you have a certain amount of additional fuel at 2k rpm, and at 4k rpm you have double (roughly) the amount of additional fuel you had at 2k rpm. By 6k rpm you have three times the amount of extra fuel you had at 2k rpm.
Likewise, when going from 9 psi to 18 psi, if you keep the A/F ratio the same (12.0:1 perhaps) you have now doubled the amount of extra fuel without even adjusting the A/F ratio.
(This is where I think a lot of people make their mistake. They don't realize that as rpm and/or boost rises, if they keep the same A/F ratio, they are automatically adding more and more extra fuel. I believe most people think they need a bigger margin of error at higher rpm, torque peak, higher boost levels -- but they don't realize they are getting it if they keep the ratio the same. They don't seem to fully grasp the ratio part in "Air:Fuel Ratio".)
If you're tuning to 11.4:1 (typical from what I've seen) you're doubling the amount of over-fueling I recommend. If you're over-fueling to this amount to keep your engine alive, I suggest you take a look at your engine/turbo system and find the one or more contributors to your inefficiency before you continue trying to make power. If you're doing it for another reason, by all means, keep on truckin'.
If you're tuning to 10.8:1 (I've seen it all too often) you're tripling the over-fueling I recommend, probably dumping black smoke during WOT and washing away the oil from your cylinder walls each cycle with fuel. If you're over-fueling to this amount to keep your engine alive I posit your engine/turbo system is completely hacked together and you might want to seek professional assistance with your build.
Старый 25.07.2016, 20:36   #2
IvanVR
Аватар для IvanVR
Авто: MMC Galant E39A RWD - лето, 4WD+4WS - зима. Honda Prelude 4g63t. ВАЗ 2106
Zaebataja stateyka
Любишь кататься - люби и с движком е....аться!
IvanVR вне форума   Ответить с цитированием Перейти в начало страницы Перейти в конец страницы
Старый 25.07.2016, 21:11   #3
Junkman
Аватар для Junkman
IvanVR,
да, ёпт... кому надо прочтёт и на английском
Старый 01.08.2016, 15:25   #4
Artem
Аватар для Artem
Junkman, конечно,пользуясь переводчиками,вот только нихрена он не поймет
Старый 01.08.2016, 18:28   #5
IvanVR
Аватар для IvanVR
Сообщение от Junkman Посмотреть сообщение
IvanVR,
Жор, статья и правда хорошая. Но сам понимаешь, технический английский... куда фильм " Красная жара попала". Сколько споров по этому поводу, имею ввиду по соотношкению воздух/топливо. Ясно одно, даже если и эту статью прочли, чем беднее смесь - тем больше мощности. Забеднение смеси, с учетом кноков, не факт, что афр для любого двигателя будет точно такой же, как у какого нибуть знакомого. " Настройка - дело тонкое" ( Белое солнце пустыни))
Старый 02.08.2016, 20:03   #6
Junkman
Аватар для Junkman
IvanVR, нууу, вообще эта статья хорошо пересекается с вот этой https://www.drive2.ru/b/2311860/.
Коротко- не надо угол накручивать, надо работать со смесью.
Новая и Очень хорошая вешь vitalivr4 Тюнинг 3Si 8 15.09.2010 11:55
Дифференциалы (LSD) хорошая статья с картинками! ANDREYKA Машины других марок 0 23.01.2010 23:24
Очень хорошая тема про ABS с коментариями BRIAN Обслуживание и Эксплуатация DSM 37 07.12.2008 21:04
Хорошая темка для FWD. kaermis Тюнинг DSM 2 08.02.2008 18:55
новая хорошая турбина для города Butcher Тюнинг DSM 12 14.03.2007 12:46
