21.03.2007, 20:08
Авто: G3 3.0 V24 2001год механика
Щиток приборов!!!
Сегодня мне ставили сигналку, и когда сняли щиток приборов обнаружили кучу сгоревших лампочек, и значков под ними. Кто нибудь раскажите, что там есть! А еще что обозначает индикатор с машиной в заносе
Последний раз редактировалось EisVintura; 21.03.2007 в 20:41..
21.03.2007, 20:26
Авто: мазда 6 2008г
Трэкшн
21.03.2007, 20:36
21.03.2007, 20:43
Теперь для чайников, сто такое ТРЕКШН, и TCL?! И как с ним боротся?!
21.03.2007, 21:07
- The Supplemental Restraint System (SRS) is designed to supplement the driver's and front passenger's seat belts to help reduce the risk or severity of injury to the driver and front passenger by activating and deploying
both front air bags in certain frontal collisions.
- If the throttle is opened excessively when a vehicle is started or accelerated, the driving wheels may slip
due to excessive drive torque. This adversely affects startability, accelerating ability or controllability. To
ensure startability, accelerating ability and controllability, this TCL system will prevent wheel slip
by controlling (applying) brake fluid pressure to the drive wheels to adjust the driving torque according to
road conditions. Each wheel-speed sensor detects wheel speed and converts it to an electric signal. The
ABS-ECU determines which wheel begins to slip according to that signal. If the ABS-ECU determines
wheel slip, it activates the solenoid valves and the pump inside the hydraulic unit to prevent the wheel
slip by applying brake ensuring controllability. This TCL system is controlled by the ABS-ECU, and the
TCL components are shared by the ABS system. If the ABS hydraulic unit is faulty, the ABS-ECU must
be replaced.
22.03.2007, 17:54
Да ужж)))
Добавлено через 20 часов 25 минут
Сообщение от EisVintura
И еще если нет АВС то какой нафиг трекшен контроль?!!!
Последний раз редактировалось EisVintura; 22.03.2007 в 17:54..
10.05.2007, 01:12
Авто: exD53A, Wrangler TJ 2.4 MT
вопрос по индикатору TCL
сейчас возвращался домой, активно порулил с ускорениями и торможениями
смотрю на приборном щитке зажглась лампочка TCL (первый раз увидел), отключилась только после того как перезавел машину
поискал как хоть расшифровать аббревиатуру,.. трэкшн контрол и как раз по ситуации включился (почему не отключился тогда?), но!, по расшифровке вина на дсм-гараже, у меня нет TCL в комплектации
что это могло быть?
Жизнь хитра! Когда у меня на руках все карты - она внезапно решает играть в шахматы...
10.05.2007, 09:23
10.05.2007, 10:57
ABS есть
ГУР - есть, АБС - есть
TCL - нет, ASC - нет, AYC - нет, Круиз - есть
Подушки безопасности: водителя - есть, пассажира - есть, боковые - есть
Кондиционер - есть, Климат - нет
этот топик читал, и вот этот тоже
http://www.eclipse-club.ru/forum/ind...ic=1065&hl=tcl
10.05.2007, 11:03
я той штуке не очень верю
vin - в личку
24.07.2007, 01:40
отключение TCL
собственно, немного стала раздражать периодически выскакивающая ошибка ввиде загорающейся лампочки TCL при активной езде, и гаснущей через какое-то время
в свое время, быстрый поиск по инету подсказал мне, что обычно машины обладающие TCL имеют и пресловутую кнопку )) в G3 же как я понимаю ее нет
мануал подсказывает, что схемы TCL и ABS тесно взаимосвязаны..
собственно кто-нибудь занимался сабжем или может посоветует, что сделать?
24.07.2007, 11:17
"обычно" имеют кнопку...да, но толку
есть у меня такая кнопка, я разницы не ощутил, ну может чуть больше cрыв колёс при старте
24.07.2007, 14:18
кажися есть предохранитель
24.07.2007, 14:32
индикация на приборке сохраняется
это инфа от датчиков abs
24.07.2007, 15:13
кстати вариант, а лампочку просто отключить
